IPSec VPN. How to create connection with multiple local and remote networks
Create multiple "Connections" on the same "Gateway".
5
Command line interface.If this arrangement sucks for you, sucks for me too, but it's the way that Zyxel request for making it work.I know there's a limit of tunnels (gateways) dependent from the device model, i don't know if there's a limit for subnets/connection/tunnel on the same gateway.0
@Zyxel_Cooldia might worth some example, if you could...Site1: subnet192.168.199.0/24Site2: subnets
172.31.99.0/24172.31.128.0/24172.31.158.0/24How can be implemented the policy routing on Site1 with only a 192.168.199.0/24 <> 172.31.128.0/24 VPN connection?
5 -
Hi @mMontana,
Thanks for the example.
In site 1, add policy route for subnet 172.31.128.0/24 routing.
src = 192.168.199.0/24
dst= 172.31.128.0/24
next hop = Site to Site VPN tunnel
In site 2, add policy route for subnet 192.168.199.0/24 routing.
src = 172.31.128.0/24
dst= 192.168.199.0/24
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
