USG60W+VPN error Phase 1SA
zimmi10,
Here a configuration guide for reference if you are using Zyxel IPSec client.
It's more simple to just download the VPN settings from USG to your VPN client by user.
https://businessforum.zyxel.com/discussion/449/how-to-configure-ipsec-vpn-with-zywall-ipsec-vpn-client
Yes i follow, i can download the vpn settings but allways this error
Hi @zimmi10
Did you select correct key group on your USG and VPN Client?
The default key group on USG phase 1 is DH2, and in phase 2 PFS group is DH2.
You can click "show advance setting" to displaying VPN setting more detail.0 -
my advance setting
i change to DH2 but no issu!0
Hi @zimmi10
I will send you private message for check this issue more detail.0
- 588 USG FLEX H Series
- 477 News and Release
