USG 500 default SSL certificate not trusted inside LAN (on content filter warn pages)
Emerald
Emerald Posts: 36 image  Freshman Member
Hi have a issue where when users hit a site that is set to warn by the content filter (ie i have one for uncategorized) users are getting a "
Your connection is not private"
NET::ERR_CERT_AUTHORITY_INVALID
certificate error from the zywall rather than the warning webpage.
Users can proceed and do get the zywalls content filtering "Access Restricted" page
Objects > Certificates > default looks good
Any pointers please?
  • Emerald
    Here is a example,
    I hit a site and should get warning page, but i get teh error
    We then get past that error to get this page (which is what we want first..)
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @Emerald
    This phenomenon is caused by when the CF detects it's an unrated website and then would redirect to the CF built-in warning page but your browser doesn't trust Zyxel device's certificate. Please refer to this link USG60 - SSL VPN connect but "this connection is untrusted, there was another user who encountered a similar problem like yours.
    I  can reproduce it as well.
    To see the certificate info.
    You will find it belong to the device's certificate.
    So, you can trust this link and redirect to the CF warning page. Thanks.
  • Emerald
    Thanks for response.
    When you say "you can trust this link and redirect to the CF warning page" do you mean each user would do this each time they get the issue?
    My customers users need to be spoon fed, they are getting this error and calling help desk. Anyway I can stop this and only present the CF page?
    - i have pushed out the default cert via group policy (no good)
  • zyman2008
    zyman2008 Posts: 243 image  Master Member
    50 Answers First Comment Friend Collector Eighth Anniversary
    Here my point of view,
    There no option to disable the CF page in Zyxel firewall.
    Even though it has this option. It'll cause other kind of support call for you.
    Since users will get a blank page said, "ERR_CONNECTION ..."
    To set the "Unrated" web page action to "Pass" can decrease the chance to block unknow sites and complain from users. And I think that's acceptable balance between convenience vs security.
    That's the way to do without each user involved.
    But without SSL inspection enabled. Users will still get the certificate warning.
    Even the certificate imported into every client devices.
    It's the reality the HTTPs protocol designed to protect the man-in-the-middle.
    No one can broke the rule.
  • Emerald
    Thanks for response, and apologies in im not seeing it, i do really value the support.
    I do under stand why im getting this error, ive never done SSL inspection with any router due to the difficulty of deploying certificates to endpoints. - The URL is still the desired site but he page is from the zywall.
    How come all is fine on a blocked webpage warning ? see pic below, we get the blocked page from zywall with no SSL error ? (yes the url is porn.com, the page content is from the zywall, yes hte site is "not secure" but i had no issue wiht error pages prior) - whats the difference?
    Based on the above - really a better work around for me would be to "block" rather than "warn" at least the users get a clear message.
    Could a work around be >> I see on the "general page" i can have a Redirect URL for blocked page. Would it be a valid feature request for a redirect URL for a Waring page
    Thanks in advance
  • Zyxel_Jeff
    edited November 2022
    Emerald
    Thanks for your feedback. It seems you use http URL not https URL so won't redirect to "need to trust certificate" page. You could use https URL and try it again. Thanks.
  • Zyxel_Jeff
    Hi @Emerald
    Thanks for your idea. We already considered implementing this feature in our next-generation firewall product. Thanks.
