Switch XGS1250-12 - V1.00 Patch 2 Firmware Release
Zyxel Switch XGS1250-12
Release Note
August, 2022
Firmware Version on all models
(Click Hyper link to download the firmware directly)
Zyxel XGS1250-12 - V1.00(ABWE.2)
New Feature and Enhancements
No. |
New Feature and Enhancements |
1. | Adjust 10G Ethernet port parameter for better overheat protection design. We strongly recommend user to upgrade to the latest firmware to have better overheat protection for Switch with 10G port operation. |
2. | Support Overheat Protection that prevents the switch from overheating. If any 10Gbps Ethernet copper port overheats for too long without proper ventilation, the port speed will decrease from 2.5G/5G/10G to 1G for switch protection. |
Bug fix
No. |
Bug fix |
1. | [eITS#220200586] Switch port is unable to be set as non-member in any VLAN when LAG group is enabled. |
2. | [eITS#220200586] After changing QoS type to IEEE 802.1p QoS, switch still displays Port-based QoS. |
3. | [eITS#220301352] Switch port speed will not change even click “Apply” button. |
Please refer to the Download Link for more details.
Adam
Thank you for the new Firmware!
Nevertheless I would want to have an option to activate the fan rather than degrading the speed.
Also is would be cool to be able to configure limit when to activate the fan so it can be costumized.
What do you think would it be possible to add? Thanks and have a good Weekend!0 -
Hi @Frantik85,
Thanks for your valuable suggestion.
We help you to post your idea in our ideation section as below link:
https://community.zyxel.com/en/discussion/15189/feature-request-fan-control-of-xgs1250/p1?new=1
Adam
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
