VPN SSL can't connect with SecurExtender. SecurExtender reconize the server
Hi @infojopi,Please send the startup-config.conf file of USG20-VPN or the web GUI access of USG20-VPN to me in private message. Thanks!0
Hi @J25White,You can use the commands to change the certificate.Router> configure terminalRouter(config)# ip http secure-server cert defaultOr disable "Authenticate Client Certificates".Router> configure terminal
Router(config)# no ip http secure-server auth-clientRouter(config)# write
- 588 USG FLEX H Series
- 477 News and Release
