USG60W+VPN error Phase 1SA
zimmi10,
Here a configuration guide for reference if you are using Zyxel IPSec client.
It's more simple to just download the VPN settings from USG to your VPN client by user.
https://businessforum.zyxel.com/discussion/449/how-to-configure-ipsec-vpn-with-zywall-ipsec-vpn-client
Yes i follow, i can download the vpn settings but allways this error
Hi @zimmi10
Did you select correct key group on your USG and VPN Client?
The default key group on USG phase 1 is DH2, and in phase 2 PFS group is DH2.
You can click "show advance setting" to displaying VPN setting more detail.0 -
my advance setting
i change to DH2 but no issu!0
Hi @zimmi10
I will send you private message for check this issue more detail.0
- 392 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 78 Nebula Status and Incidents
- 5.1K Security
- 51 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 70 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 332 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 880 Nebula FAQ
- 415 Security FAQ
- 220 Switch FAQ
- 195 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 72 About Community
- 63 Security Highlight
