USG60W - can WAN ports be setup as primary and fail over?
Jon_Kelly
Jon_Kelly Posts: 1 image  Freshman Member
edited April 2021 in Security
Would like to use USG60W, to have the 2 WAN ports, but need to run on one port, and the other port would be for fail over.  Both ports working together will not work for me.
Is that possible with this unit, WAN1 primary, and WAN2 as fail over?
  • Zyxel_Stanley
    Hi @Jon_Kelly
    You can add a trunk interface for your environment.
    Configuration > Network > Interface > Trunk > Add User configuration.
    And apply it as default WAN trunk.
