NWA1123 - cannot access GUI
Hi community
I use three NWA1123-AC v2 and manage them via Nebula and they work perfectly
I have one spare NWA1123-AC v1 lying around that I like to use in my garden in conjuction with the Zyxel outdoor case SKU 4792.
Unfortunately I have issues while configuring the wireless-settings. I experience the following problem:
- login in as admin
- click on configuration on the left side
- prompt to login again
- I see the mainpage a second time in the same window
- even after a "second" login I cannot access the wireless-settings
here are the details
I use Firefox 106.0.5 on mac os 13.0.1 (22A400). Several restarts and even resets didnt help.
Kind regards
Andrew
Same behavior with Safari?
thats a good advice I didnt think of, thanks. actually in Safari it works fine. I just have to make sure to logout correctly and dont just close the window, otherwise I get the following message from Safari. It means that the server has unexpectedly terminated the connection.
- 441 Beta Program
- 210 Nebula Ideas
- 538 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
