NWA1123 - cannot access GUI
Wookie
Posts: 45 Freshman Member
in WirelessLAN
Hi community
I use three NWA1123-AC v2 and manage them via Nebula and they work perfectly I have one spare NWA1123-AC v1 lying around that I like to use in my garden in conjuction with the Zyxel outdoor case SKU 4792.
Unfortunately I have issues while configuring the wireless-settings. I experience the following problem:
- login in as admin
- click on configuration on the left side
- prompt to login again
- I see the mainpage a second time in the same window
- even after a "second" login I cannot access the wireless-settings
here are the details
I use Firefox 106.0.5 on mac os 13.0.1 (22A400). Several restarts and even resets didnt help.
Kind regards
Andrew
Same behavior with Safari?
thats a good advice I didnt think of, thanks. actually in Safari it works fine. I just have to make sure to logout correctly and dont just close the window, otherwise I get the following message from Safari. It means that the server has unexpectedly terminated the connection.0
- 397 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 78 Nebula Status and Incidents
- 5.1K Security
- 52 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 70 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 332 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 880 Nebula FAQ
- 415 Security FAQ
- 221 Switch FAQ
- 195 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 72 About Community
- 63 Security Highlight
