Is there a configuration converter that will work for Zywall 110 (firmware 4.38) to ATP200?
Hi @ITWORX,Welcome to Zyxel Community.
We have configuration converter for easy migration.However, it does not support convert from ZyWALL110 to ATP200 directly.You can send me your Zywall 110 configuration via private message.I will help you to convert from Zywall 110 to ATP200.Configuration converter:
https://www.zyxel.com/promotions/usg-configuration-converter-20130829-760081.shtml
Received File. Thank you.
Hi, i have the same problem but with firmware 4.72...Zyxel_Cooldia can you help me?
Thank you0 -
Hi @Masino,Do you need to convert the configuration file from ZyWALL 110 to ATP200? Please send the configuration file of ZyWALL 110 to me in private message.0
- 441 Beta Program
- 210 Nebula Ideas
- 534 USG FLEX H Series
- 338 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
