USG60W - unable to connect to the WLAN
vguichard
vguichard Posts: 1  Freshman Member
Fifth Anniversary
edited April 2021 in Security
After updating to the last Firmware (4.32), we are starting to have troubles with the WIFI connection.The problem appears after a few weeks of functioning. The devices can see the SSID, but the connections are closed immediately after being initiated. No modifications can be done on the radio setting at this time (for example, if we change the SSID, the annonced SSID is still the previous one. Only solution seems to reboot USG60W.
Radio configuration has been remade from scratch, but the problem still occurs.
Should I roll back to 4.31?
