PRIVATE NETWORK ATP 200
Dear,
Can you tell me how should I configure so that a specific
device is blocked from connecting to the internet, only allowing that
device to have its connection on the local network?
Should I create a user and assign the IP of the specific machine to block its access to the WAN? Would it be something like this? I only need to allow connection to the local network.
Hi @pykue,
Greeting forum . Assuming you have 192.168.100.0/24 in LAN1 , 192.168.3.0/24 in DMZ.
Conditions are LAN1 can access DMZ but cannot access internet .
Thus, you will have the following rules.
Order1 for LAN1 block to internet , order2 for LAN1 can access DMZ.
Thank you
Kevin0 -
Dear,Could you please send me a manual on how to configure?I'm using only LAN1, should I plug the device (which must have limited connection) in DMZ?I need to access this device via LAN, JUST BLOCK HIS CONNECTION TO THE INTERNET.0
Then put a rule on top of From LAN1 to WAN1 that says "from your device IP to WAN action deny".Consider to configure a LAN1 DNS server.0
There's something missing in the recommendations you gave me, I didn't understand anything.I have already tried the following items:Object > Address/Geo IP,I created a host with the IP that must be blocked for internet.Then I went to:Security Policy> Policy controlI created rule:From LAN1 - SOURCE (device blocked at Object > Address/Geo IP), - to WAN (I also tried to ANY excluding zywall), both did not work, the device continues to communicate with the internet.0
If you have access to this device you could setup the IP manually without a gateway this would limit the device to the subnet its in.
Hi @pykue,
Please ensure the rule have the highest order (rule #1),
Please see the below picture to share your configuration if it is still failed . Thank you .
Kevin0
- 241 Nebula Ideas
- 6.8K Security
- 755 USG FLEX H Series
- 379 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 320 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
