Register ATP500 without Services
Hi @Eric_We already reset license services for you.You can register the device again when you want.Thanks.0
I have not run in to this problem with many of my firewalls when registering it possible as you was click through you had the option to enable then.
Its possible Zyxel could make this more clear by doing the registering only and then you have to login to enable the services.
Hi @Eric_Thanks for your feedback and experience sharing with us. Could you provide your mac address and the serial number of the ATP500 to us via private message? Thanks.0
Hi @Eric_
Once the user enters the brand new device's Web-GUI and the Initial Set Wizard would guide the user to complete Register Device and activate license services procedures, it's a current behavior. But if you activate the license service by accident and the device still remains a trial license we might reset the license for you by a special case. So, please provide the serial number and mac address to us first.
Additionally, I quoted a discussion that has a similar question as below. It could help other users to clarify that situation. Please refer to it:
"When you enter the brand new device first time, here is an Initial Setup Wizard to guide you on how to complete your device setting. Especially, there is a Register Device procedure and you could click the Register button on this screen to register your device at portal.myzyxel.com.
Then It will redirect to Myzyxel.com. then login with a Myzyxel account to proceed register procedure.
Once it is completed, you can see the message Your device is already registered. Now you can activate all security services. Click Activate All to activate UTM services.
Go back to Initial Setup Wizard, and click Refresh, we can see that Device Register status change to Registered.
Click Next to continue
Click Refresh to check Service License Status.
Click Next to continue the remaining initial Setup Wizard.
Hello Jeff,Thanks for the explanation.If I look closely at the last screen then it shows "activate service" but the status shows "activated" an no option to skip the service activation. Activated to me means it is a done deal, no change possible.I was never asked if I want to activate these services, it was immediately done!GreetingsEric0
Hi @Eric_
Thanks for your comment. We already received your private message for the device information. I will inform you later.0 -
- 441 Beta Program
- 533 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
