Problem with update ZyWall USG-100Plus to firmware 330 AACV v3.30P9 (WK48)
Hello!
A problem with update the old ZyWall USG-100Plus to the firmware from the post https://community.zyxel.com/en/discussion/4247/zywall-usg-series-v3-30p9-wk48-firmware-released
When I try to update firmware from the current 3.30(AACV.7)ITS-WK28-r72114 to the "USG 100-PLUS 330 AACV v3.30P9 (WK48)" process stopped.
On the console displays:
[Update Filesystem]
Updating Filesystem
[/util/zld_fsextract]
and rotated slash.
At this stage (slash rotated) very long time (one week) without any others actions. I was able to interrupt it only by turning off the power, after which the device does not boot with the message on the console:
FLASH: AMD 16M
BootModule Version: V1.17 | 12/01/2011 05:20:17
DRAM: Size = 256 Mbytes
Kernel Version: V2.6.25.4 | 2016-07-14 09:27:45
ZLD Version: V3.30(AACV.7)ITS-WK28-r72114 | 2016-07-14 10:14:06
Press any key to enter debug mode within 1 seconds.
BM cmd line: console=ttyS0,115200 root=/dev/ram init=zyinit "-r /dev/sda", address: 0x100000
Uncompressing Linux...done.
Start to check file system...
/dev/sda2: 26/17352 files (3.8% non-contiguous), 16993/69296 blocks
/dev/sda3: 152/41120 files (28.9% non-contiguous), 45664/163841 blocks
Done
mount: wrong fs type, bad option, bad superblock on /dev/loop0,
missing codepage or other error
In some cases useful info is found in syslog - try
dmesg | tail or so
Kernel panic - not syncing: Attempted to kill init!
I tried hardware reset device before upgrade - it didn't affect. What could be the reason and how can I flash the device to the lasted firmware?
I can restore the device via flashed the database ("Firmware restore" didn't help). After the restoration the device works normally with the old firmware and all my old settings.
Hi @a1601,Kindly check the file hash is correct, "SHA1 330AACV7ITS-WK48-r74988.bin":a4dd20d498934ad6c18d15b2f4ec7dab23c61cd9
And install the weekly again. If the issue still persist. We can have remote session.
Please feel free to contact me .Thank you
Kevin0 -
Hello! Unfortunately I've same problem. I was check hash of 330AACV7ITS-WK48-r74988.bin, is right. Can you answer, how you solwe this problem, if so?0
I can't use any old firmwares, because I've no one of them) And didnt find any way to restore previously installed. Do you have an old image applicable for recovery? Can you share it with me?0
To restore device without firmware update i'm using instuction from https://support.zyxel.eu/hc/en-us/articles/360014273779-Firmware-Recovery-Process-on-USG-ATP-VPN-FirewallsConnect to the console port, reboot the USG and enter to debug mode ("Press any key to enter debug mode")In debug mode enter at command:atkz -f -l 192.168.1.1
atgof
Connect my PC direct at the specified ethernet port (6), get access to USG FTP (IP 192.168.1.1, i'm using WinSCP) and upload the current USG firmware bin-file (not new or updated) to the device.After the automatic reboot the device worked completely.
What firmware was before trying to flash a new one? I did not try this metod to upload the another version firmware (not the one that already was) and I don’t know what will happen if flash some other.0 -
I did it by same instruction, but I use "330AACV7ITS-WK48-r74988.bin", not my current version of firmware. Maybe I misundestand something? How can I obtain "current USG firmware bin-file"? Now Im leave house till morning, yesterday will see version of running firmware.0
Send me the current version of firmware. I have a some firmware files in the archive, if exist right - I will send it to you. Also, I think, all firmwares can be found on the Zyxel sites (but my old saved links dead now).0
My version displayed as "ZLD Version: V3.30(AACV.7) | 2015-01-14 21:15:46", I hope is old version number, not version of unsuccsesful update. If you have this one its will be great. All of firmware archives with old stuff on Zyxel is dead from 2021, I cant find any other sourse. Seems like discontinued products become thruly discontinued, only community can help.0
Need the full number of firmware version ("V3.30(AACV.7)ITS-WK28-r72114" for example). You can see it at the top when booting device before "enter debug mode", like in my first post:
FLASH: AMD 16MBootModule Version: V1.17 | 12/01/2011 05:20:17DRAM: Size = 256 MbytesKernel Version: V2.6.25.4 | 2016-07-14 09:27:45ZLD Version: V3.30(AACV.7)ITS-WK28-r72114 | 2016-07-14 10:14:06Press any key to enter debug mode within 1 seconds.
-------------------------I believe (by date) this is the version 3.30(AACV.7)C0Link to download: https://dropfiles.org/gRHDRIXK1 -
FLASH: AMD 16MBootModule Version: V1.17 | 12/01/2011 05:20:17DRAM: Size = 256 MbytesKernel Version: V2.4.27 | 2015-01-08 20:52:20ZLD Version: V3.30(AACV.7) | 2015-01-14 21:15:46Press any key to enter debug mode within 1 seconds......................BM cmd line: console=ttyS0,115200 root=/dev/ram init=zyinit "-r /dev/sda", address: 0x100000Uncompressing Linux...done.You sent to me right firmware and now my brick turned to the USG100 plus again! Thank you!)0
- 384 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 79 Nebula Status and Incidents
- 5.1K Security
- 73 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 70 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 332 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 886 Nebula FAQ
- 415 Security FAQ
- 228 Switch FAQ
- 198 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 63 Security Highlight
