NWA220ax-6E: no WIFI 6
MaDa99
in WirelessLAN
I switched Bandflex to WIFI 6. But not one device recognize it.
I use:
All devices are only connected with 2,4 GHz.
My AP has the latest firmware.
What's happend?
I use:
- Mac Studio Ultra with macOS Vetrura
- MacBook Pro M1 2020 with macOS Vetrura
- MacBook Pro M1 2021 with macOS Vetrura
- iPhone13 ProMax with iO16.x
- iPhone11 Pro with iO16.x
What's happend?
Best Answers
Hi @MaDa99
IEEE 802.11ax is a protocol.
Wi-Fi 6 and Wi-Fi 6E are based on 802.11ax to produce.
Wi-Fi 6E adds the 6G radio frequency, and devices require hardware support.
So you need to check the product spec supported Wi-Fi 6E (802.11ax)
That product will support 6G radio.
Jay
Hi @MaDa99Yes, all devices are based on IEEE 802.11ax, but the Wi-Fi 6 and Wi-Fi 6E protocols were created based on 802.11ax. Devices require hardware support to support 6G radios. Wi-Fi 6 product doesn’t have the hardware support to connect to 6GHz.We have checked with Apple TW Support.Now only iPad Pro (M2) (2022) can support 6GHz, please help us double-check with your Apple Support. Do their product support 6Ghz radio frequency?Thank youJay0
Hi @MaDa99Unfortunately, now Apple product that supports WiFi-6E is the iPad Pro (M2) (2022).All of your Apple devices are only supported 802.11ax Wi-Fi 6 wireless networking.They don’t support Wi-Fi 6E protocol, so you can’t use the 6G radio with your Apple devices.Jay0
Hi Jay,
Thanks for the answer. But I am wondering a lot right now....Mac Studio Ultra: https://www.apple.com/de/mac-studio/specs/
WLAN: 802.11ax WLAN 6
MacBook Pro: https://www.apple.com/de/macbook-air-m1/specs/
iPhone 13 ProMax: https://support.apple.com/kb/SP848?locale=de_DE
WLAN 6 (802.11ax) mit 2x2 MIMO
...and so on.What am I misunderstanding about the specification WLAN 6 802.11ax
Marko
Hi @MaDa99
Jay
Thanks Jay, I think that means that all devices based on IEEE 802.11ax should connect to the NWA220ax-6E.But they didn't.I will ask Apple.
Sincerely, Marko0 -
Apples Support said to me, all devices should be able to connect.0
Thank you. 5 GHz works fine.
I thought I could use 6Hz, that was probably a misconception.
Hi @MaDa99I'm sad that your Apple Support gives you the wrong answer.We have checked with Apple TW. And they said they will report the issue to Apple Germany Team.Unfortunately, they don't have any articles to explain the spec.To let you can understand easily, we compare the none-supported-6G Apple product spec and the supported-6G Apple product spec for you.As the picture, now if the apple product supports 6Ghz, they will only mark the Wi-Fi 6E to let the customer know.Thanks for your response to let the people know this issueJay0
- 347 Beta Program
- 2.1K Nebula
- 115 Nebula Ideas
- 77 Nebula Status and Incidents
- 5K Security
- 44 USG FLEX H Series
- 246 Security Ideas
- 1.2K Switch
- 64 Switch Ideas
- 900 WirelessLAN
- 33 WLAN Ideas
- 5.8K Consumer Product
- 204 Service & License
- 326 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.8K FAQ
- 832 Nebula FAQ
- 402 Security FAQ
- 219 Switch FAQ
- 190 WirelessLAN FAQ
- 45 Consumer Product FAQ
- 136 Service & License FAQ
- 71 About Community
- 61 Security Highlight
