Firmware for ZyWALL 2 Plus
Hello, I'm new here, new job, new legacy hardware to manage... so here is this old ZyWALL 2 Plus and I'd like to update its firmware. However this model is not listed into MyZyxel portal.
Where can I find the firmware for it?
    PeterUK Posts: 4,267 image  Guru Member
    edited December 2022
    You likely have the upto date firmware
    Very old the FTP server has gone support out the window you should look into a newer model.
    VPN Firewall | Zyxel Networks
    I'm afraid I have not the latest, because I have a release from year 2009 and, from a google search, it looks like there exists at least a release from year 2014
  • mMontana
    mMontana Posts: 1,443 image  Guru Member
    I personally doubt about 2014.
    According to files in my possession, latest released is "named" 4.04 XU.11, it's dated february 2011 and release notes are signed by Mr Billy Bian.
    Datasheet reports 10/100mbps ports, 3000 concurrent connections, less than 25MBPS of throughtput, 5 IpSec tunnels, bare AES128 support.
    It's old, fainting, vulnerable and venerable device. A SOHO router out of support like VPN2S has better performances, more options, less unpatched vulnerabilities and can be managed via modern browser. You love it as a museum toy? Fine by me, I have one too.
    Don't consider to install it. By different orders and degrees, is a really bad idea.
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,568 image  Zyxel Employee
    Welcome to Zyxel community. The latest firmware is 404XZ0D0.bin. i can send it in PM if you need latest firmware.
    We strongly recommend replacing ZyWALL 2 Plus since it is phase out and no firmware maintenance.
    You're right, the latest it's a 2011 release, but even then it's 2 years younger than the 2009 release I have.
    Fact is, it is already in production since then, I'm only supposed to take over its maintenance. It's actually doing its job, no reason to replace it (except maybe security wise, but it's only running a small LAN of trusted computers).
    Please do.
    I'm not in charge for that decision here, but I'll report that suggestion upstream for sure, thanks.
  • mMontana
    I'm pretty sure that it's doing fine: as I sad i have one of that and served as internal router (after the CPE for splitting traffic and avoid nose picking from the ISP) for 4 years from 2016 (which was already out of support and strongly suggested to not use it). I criticize Zyxel but on firewall the hardware is really resilient and reliable.
    However if that device is publicly reachable in any way is like driving a car without MOT/Vehicle approval. It works, is doing what's intended to, but when I's time for police checks (certifications) or accidents (security breakouts) might unreasonable the level of hassle. Every device behind that firewall is in heftier and greater risk than with a newer one.
    As the one supposed to maintenance that, you're like the car mechanic that make that car run. IMO you should not allow that because it will bring you complicity for some issues. If you maintain an equipment which is unsafe, some laws might consider you co-liable for the fallout.
    You can still request for dated and signed exclusion of liability if anything happens under your maintenance duty about that device.
  • lucrus
    lucrus Posts: 4
    mMontana said:
    However if that device is publicly reachable in any way...
    It's not. At least not  directly. An attacker has to hack other routers before reaching that one, and, in that case, said attacker hacking that one would be the least problem.
    Thanks for the heads up, but at least here in Italy that resembles a sci-fi by a screenplay writer used to get high during work hours... believe me, none of that is going to happen here, at least not in the somewhat smallish company I work for.
  • hi - if possible
    pleas sesend me too the latest zywall 2 plus firmware - i'm in
    Model
    ZyWALL 2 Plus
    Bootbase Version
    V1.11 | 07/12/2006
    Firmware Version
    V4.02(XU.3) | 07/31/2007
    and my purpos is only for study and test and lab.
    Alberto
  • Zyxel_James
    Zyxel_James Posts: 809 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    @AlbertoMantovani Please check your inbox, thanks.
