ZW USG 1100 don't release DHCP adresses
Hi @alexey,
Please kindly install the latest weekly firmware.
https://community.zyxel.com/en/discussion/14386/zld-v4-72-wk35-firmware-release#latest
We have some fixes for the DHCP daemon.
Thank you0 -
No, this FW don't fix problem.Zyxel_Kevin said:Hi @alexey,
Thank you
Today i met this problem again.0 -
Perhaps try the latest firmware (4.73)?
Hi @alexey,
Please kindly install the latest firmware 4.73 .
If the issue still , please provide diag-info during issue happen.
Thank you
Kevin0 -
Same issue again on 4.73
Message msg="Cannot find any lease for this client - 11:22:33:44:55:66:77:88, DHCP pool full!" note="DHCP Discover" is syslog
Send diaginfo to PM
Router> show versionZyxel Communications Corp.image number model firmware version build date boot status===============================================================================1 USG1100 V4.72(AAPK.0)ITS-22WK35-r105124 2022-08-31 16:59:40 Standby2 USG1100 V4.73(AAPK.0) 2022-11-18 09:07:49 Running
What happens if you set lease to 2 mins? May be the Zywall does remove IP sooner the shorter the lease?0
Seems there is a bug with V5.35 too on my VPN300 for last access time when that Virtual PC for that IP was long shutdown.
Think the USG 1100 is EOL but I hope they roll out a fix for you.
AS it is even VPN300 V5.35 has the same bug and I think its the same bug for the old series to do with last access which the old series didn't show and the Zywall is using that to keep the lease alive.
192.168.255.50 still their. And last access seems to be a copy for all.
So for me you got DHCP table and then IP/MAC binding in monitor and the two don't link up for last access with IP/MAC binding showing correct and 192.168.255.50 gets removed from listing but DHCP table show a copy all the same last access time plus 192.168.255.50 hangs around.
After more testing here and will test on a old series here is what is meant to happen
DHCP table subnet full
IP lease expires for clients
I new client what to connect
Zywall tests a IP that has been expired by ARP to that IP
If no reply client get IP.
So maybe you have something making a ARP reply back to Zywall?
- 441 Beta Program
- 293 Service & License
- 461 News and Release
