Cannot block youtube by appPatrol
I'd move rule #3 to position #2 and test again.0
Hello @Hary1987,YouTube uses QUIC protocol and the main goal is to improve the application performance that is currently using TCP. QUIC is using UDP protocol. Please add a firewall rule to block UDP 443 and test again.If youtube still be unblocked, please provide your configuration via PM, and I will check on the settings for you, thanks.James0
- 588 USG FLEX H Series
- 476 News and Release
