DHCP not working on vpn100
hi
I have a remote site where using vpn100 and the remote site is connected to the main site via a VPN tunnel. tunnel works fine but the remote side vpn100 is not assigning auto IP to devices and I have to add manual IP then the clients work. I have updated the latest firmware also on the remote site VPN 100 is still DHCP not working.
I just got the error as per the attached picture but it never shows up again.
the settings were never changed so not able to find the cause of not assigning auto dhcp.
Thanks James for your quick reply.
I mange to fix it .
seems some port forwording was causing this issue and after deleting that dhcp started to work.
thx
Onkar Singh
Hello @SNTL,Please provide the configuration and diag-info for further checking, you can send them to me via private message, and I will check on this for you, thank you.James0
I mange to fix it .
thx
Onkar Singh
- 441 Beta Program
- 532 USG FLEX H Series
- 333 Security Ideas
- 51 Wireless Ideas
- 293 Service & License
- 461 News and Release
