Connection with Internet provider
Your ISP provides you with a PPPoE (Point-to-Point Protocol over Ethernet) and a subnet mask limiting you to only 1 single IP address. PPPoE also means you need to set up your connection as a PPPoE connection with username + password (separate PPPoE page fields). Your will not have a connection to internet before you have configured the PPPoE part of your internet connection setup.
Use the setup wizard if you are uncertain how to do this. Make sure you select the PPPoE option when selecting your type of internet connection in the ZyXEL connection setup Wizard.0 -
The connection is not PPOE, but it is Ethernet I double check with my provider.
I can insert the network mask 255.255.255.254 on the wan port but it seems not working.
Here is some useful information about /30 and /31. The subnet /31 is used in point-to-point link. If you'd like to configure it on ethernet wan connection, maybe you can ask ISP to give you /30.0
I cannot ask My provider, he also shows me it works using another device. Why Zyxel does not support this /31 or there is any way to use it in a wan port ?
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
