Rename or Disable built-in Administrator
Veronesi
Veronesi Posts: 24 image  Freshman Member
First Answer First Comment Friend Collector
edited April 2021 in Security
Hi
I have several USG1100, USG110 and one VPN100 device.
Is it possible (and how) to disable or rename the built-in Administrator account?
We'd like to get (a little bit) higher security, so that potential hackers also have to guess the username.
We already have created aditional admin accounts. But now we'd like to disable the default one.
Thanks in advance
Veronesi
    PeterUK Posts: 4,268 image  Guru Member
    You could give it a super long password
  • Veronesi
    Yes, possible... However not the preferred way to go. But maybe the only one?
  • Veronesi
    Hi @Zyxel_Stanley
    Thank you very much for your comment.
    This is a very good idea and helps me a lot!
    Thanks again!
    Veronesi
