Getting CDR alert emails. Logs say almost nothing?
ChipConnJohn
ChipConnJohn Posts: 45 image  Freshman Member
Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula First Comment Fifth Anniversary
Collaborative Detection & Response Alert
Malware found malicious activities of a client over threshold at 2022/02/08 19:13:30
Category: Malware
Security Event: Malware detected
Event counts: 2 in 60 minutes
Client information:
IP Address: 192.168.110.75
MAC address: e4:54:00:88:99
User: -
I logged into the ATP and the CDR log says nothing more.  What is it seeing?  Is there another log I can be looking at?
Thanks,
-John
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,539 image  Guru Member
    edited February 2022
    Hi @ChipConnJohn,
    CDR detection include IDP, Anti-Malware, and URL Threat Filter. You should be able to see abnormal event log in "MONITOR > Log > View Log" when you filter keyword for detected address.
    e.g.
  • Dear Zyxel_Cooldia,
    I have the same problem, the log entry of the possible found malware doesn't say anything.
    In the above example which you have added where did you get the IP-address which you entered into the Keyword field? As you can see in my printscreen the only address is my local PC (192.168.2.37).
    If I do what you have suggested I don't see anything like a malware in the logfile of my FW.
    Why can't this log-entry show directly which malware was found (name or location or any other valuable information)?
  • Zyxel_Cooldia
    Hi @JBR007,
    CDR event is trigger by Web Threat, Malware, and IPS.The notification mail is alert to firewall admin.
    For further detailed information, you can check from "MONITOR > Log > View Log"
    However, the log only keep for 2048, we would suggest to use SecuReporter for security event analysis.
