2 x SSL VPNs on two different ISP Connections
Hi All, we currently have one internet connection and one SSL VPN configured, we are thinking of getting a second internet connection is it possible to have Two SSL VPN's or configure the original VPN to use both Internet Connections - in due course we will discontinue one of the internet connections?
thank you.
thank you.
You can connect VPN via different ports (wan1, wan2) after you enable SSLVPN feature.
Not need additional settings .0 -
@Merlin some questions for better understand your desiders.As "ssl vpn connection" may I assume the the device acts as a VPN Server endpoint? (clients connect to it).
Are you aware that multiple users might connect to the same SSL VPN server?
You refer as "two ssl VPNs". What are you trying to achieve with the second one?0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
