Missing Menu after FW Upgrade
Peterp
Peterp Posts: 1 image  Freshman Member
After a FW upgrade through Nebula, I am missing Menu points on my local web administration. I tried rebooting,loading and resetting the config,but nothing helps. It feels like I lost my admin privileges.
the pic shows the available options under “advanced application”
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,531 image  Zyxel Employee
    edited January 2023
    Hi @Peterp,
    Welcome to the Zyxel community!
    This is because your switch is controlled by Nebula.
    When it is in Nebula mode, you can only configure it on the Nebula control center.
    In addition, you could reference this post to configure your switches.
    Zyxel Melen
