VPN IPsec no traffic
Amine
Amine Posts: 1 image  Freshman Member
Hello community
happy new year to all
I have to connect 2 sites by a VPN IPSec, site A has a pfsense firwall and site B has Zyxel USG 210
the tunnel is up, both phases (1 and 2) but no traffic between the networks
something wrong with the firewall policies on the USG but I can find the issue
here are the settings:
Pfsense (Site A):
Image post content
USG 210 (Site B):
Image post content
if someone have a solution or an advice
Thank you in advance
  • CHS
    CHS Posts: 181 image  Master Member
    The default firewall policies allow traffic to and from the IPSec VPN Tunnel because the latest rule blocks all traffic "From Any to Any". Therefore, the rules you mentioned should not cause any problems. You can check if any policy route rules are affecting your VPN traffic.
  • Zyxel_James
    Zyxel_James Posts: 809 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    Hello @Amine,
    We can do several checks to narrow down the root cause.
    1. Check the logs to see if any security policy blocks the traffic. Or you can disable the Policy Control to test if any security policy blocks the traffic.
    2. Go to Monitor > VPN Monitor > IPsec, select the tunnel, and click Connection Check. Also check if it's one-way block on inbound, if so, you may check on pfsense peer.
    3. Check if there is any conflict routing, you can go to Maintenance > Packet Flow Explore > Routing Status, and check which routing the session goes.
    4. There is also a possibility there is an overlapping subnet, resulting in routing conflict.
    James
