TCP-Aging in IPsec Site-to-Stie VPN
i have the problem on my usg/zywall that the comunication from
my server in network A to my ec-cash terminal in network B don't work very
well.
It seems there would be a tcp-aging in the side-to-side ip sec vpn, after about
five minutes the communication do not work as well.
The problem ist the ZVT-Protokoll the communication is only when somone payed via EC-Cash therer are no Keep-Alive packages between server an terminal.
Is it possible to turn of tcp-aging in the vpn session?
The communication port ist 22000
on network a is a zywall110
on network b is an usg20
in the attachments is a wireshark dump
please help me!
Felix
Hi @moebi
In the packets No#15, it has enabled “don’t fragment” bit, so the packets may dropped due to packets size too large.
You can enable “ignore don’t fragment” function on both of USG.
And try it again.
thanks for your help, but i have the same issue when Ignore don't fragment is enabled on both zywalls.
I also have the same problem when i tried this with port forwarding.
But it is only when i use Zywall, the old Router with dd-wrt works fine.
Is there any VPN related log on the device log page? Only the specific application will be disconnected or the whole VPN connection went down when the symptom happens?
Hi @moebi
Welcome to Zyxel Community. ?
For TCP aging, we can modify the TCP session status time out value on USG, but from the packet trace, It seems to me that it’s not related to TCP aging.
As you can see, 10.2.232.23 got no response from peer 192.168.101.40, then it send a packet with [rst,ack] frag to terminate the session.
Also, in general, application should have mechanism to handle keep-alive event, not just rely on TCP layer.
The following cli are device session settings, you can have a quick test and see if the issue is due to this.
Check device tcp session time out:
Router# show session timeout tcp|udp|icmp
Modify Device session time out value:
Router(config)# session timeout tcp-established xxx
- 243 Nebula Ideas
- 6.9K Security
- 793 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
