Can I change the inactivity time?
BigBadMadBill
The inactivity time before it logs me out is much toooooo short can I change it?
Hi @BigBill,Welcome to Zyxel Community!Based on the description, you are referring to the Service access control timeout time, right?If yes, the timeout time can be modified to the following path below.1. GS1900 Series.Web-GUI > Configuration > Management > HTTP/HTTPS
2. GS1920 SeriesWeb-GUI > Management > Access Control > Service Access Control
3. GS2210 and higher level switch.1. Web-GUI > Management > Access Control > Service Access Control
Hope it helps!
Zyxel_Jonas0
- 441 Beta Program
- 529 USG FLEX H Series
- 333 Security Ideas
- 51 Wireless Ideas
- 292 Service & License
- 461 News and Release
