Android 13/IPAD IOS 15.7 and USG40 with IKEv2
I have used earlier L2TP/IPSEC tunneling but now newer andoids doesn't support that one.
I did IKEv2 configuration according these.
https://support.zyxel.eu/hc/en-us/articles/8805317185298-VPN-Configure-IKEv2-with-Pre-Shared-key-on-Mobile-Devices-Instead-of-L2TP-
When I try make a connection I will get always error message in both devices android (SAMSUNG S20) and IPAD.
Any Ideas? KR,J
Any Ideas? KR,J
[SA] : No proposal chosen
84.250.110.101:500
221.210.110.200:39676
IKE_LOG
5
2022-12-23 05:15:26
info
IKE
[SA] : Tunnel [IKEv2_Connection] Phase 1 proposal mismatch
84.250.110.101:500
IKE_LOG
6
2022-12-23 05:15:26
info
IKE
The cookie pair is : 0xe2c0fb51341291dc / 0xfc79f4663830a392 [count=3]
84.250.110.101:500
IKE_LOG
7
2022-12-23 05:15:26
info
IKE
Recv IKE sa: SA([0] protocol = IKE (1), AES CBC key len = 256, AES CBC key len = 128, HMAC-SHA512-256, HMAC-SHA384-192, HMAC-SHA256-128, HMAC-SHA1-96, HMAC-SHA512 PRF, HMAC-SHA384 PRF, HMAC-SHA256 PRF, HMAC-SHA1 PRF, RFC5114 2048-256 bit MODP, 384 bit ECP
84.250.110.101:500
IKE_LOG
8
2022-12-23 05:15:26
info
IKE
[INIT] Recv: [SA][KE][NONCE][NOTIFY][NOTIFY][NOTIFY][NOTIFY]
84.250.110.101:500
IKE_LOG
9
2022-12-23 05:15:26
info
IKE
Receiving IKEv2 request
84.250.110.101:500
IKE_LOG
10
2022-12-23 05:15:26
info
IKE
The cookie "
Best Answers
Hi @Jokke,[SA] : Tunnel [IKEv2_Connection] Phase 1 proposal mismatchHere is Phase 1 and Phase 2 proposal that match the iOS setting for your reference.iOS: 15.6.1 on iPhone 8 PlusPhase 1
Phase 2
Test Result
IKEv2 is connected on iPhone.0 -
Zyxel_Emily said:Hi @Jokke,[SA] : Tunnel [IKEv2_Connection] Phase 1 proposal mismatchHere is Phase 1 and Phase 2 proposal that match the iOS setting for your reference.iOS: 15.6.1 on iPhone 8 PlusPhase 1
Phase 2
Test Result
Phase 2
Test Result
In a thread of some day ago we discussed about parameters setting:Now a question arise: is there a way to disable, on Android and Apple devices, vpn password save? I'd like to have users input it every time.0
The VPN secret and password setting are saved on Apple device. Maybe you should check with Apple if these settings are able to be not saved.0
Phase 2
Test Result
Hi @Jokke,For Android 13, set proposal "AES128-SHA256-DH2" in phase 1 and "AES128-SHA256" in phase 2.0
Unfortenately this does not work :( also Even this would work I shoud creat own VPN tunnel for IOS and android because Zyxel support only one IKE Diffie-Hellman (DH) group per tunnel
I am wondering is that something what is Samsung spefic, my phone is Samsung s20 with android 13
Hi @Jokke,
It seems Samsung needs two DNS server in phase 2 settings. Hence, try to configure both First DNS server and Second DNS server in VPN Connetion > Configuration Payload on USG40.0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
