Are technical specifications reduced in new ATP500 datasheet?
Kinshuk_Tech
in Security
I was reviewing the new datasheet of ATP500 firewall uploaded on 29-Dec-2022.
https://download.zyxel.com/ATP500/datasheet/ATP500_16.pdf
Few changes observed:
Regards
Kinshuk Joshi
- Zywall word is removed from product name.
- Subscription-based licensing kicks in. 1-year gold security pack gets included.
- SecuReporter Premium is no longer offered with ATP500 firewall.
- Max concurrent IPSec VPN Tunnels are reduced to 500 nos from 1000 nos.
- New datasheet is applicable on devices having firmware ZLD 5.35 and Not ZLD 5.3 as earlier quoted.
- GRE Tunnel for Campus AP & SSL inspection report removed from Geo-Enforcerer.
- Direct integration with Google Authenticator app for 2FA.
Regards
Kinshuk Joshi
Hi @Kinshuk_Tech,The content of the latest datasheet uploaded remain the same.The key difference is we have rectified the ATP700 Max concurrent IPSec VPN Tunnels to the correct quantity 500.In the ATP700 user's guide Max concurrent IPSec VPN Tunnels is 500.
As for items 3 SecuReporter, it just rename from SecuReporter Premium to SecuReporter. That's the same feature.If you need more max concurrent IPSec VPN Tunnels, ATP800 is the model with highest performance, where it's concurrent IPSec VPN Tunnels can goes up to 1000.1
Hi @Kinshuk_Tech,
Thanks for feedback. We are checking those items, will update this soon.0 -
As for items 3 SecuReporter, it just rename from SecuReporter Premium to SecuReporter. That's the same feature.If you need more max concurrent IPSec VPN Tunnels, ATP800 is the model with highest performance, where it's concurrent IPSec VPN Tunnels can goes up to 1000.1 -
@Zyxel_Cooldia avoiding my possible mistakes.ATP700 can have 500 "Phase 1/Gateways"? Or can allow only 500 IPsec connection (Site to site + concurrent client-server connections + concurrent L2TP client-Server connections)?0
Hi @mMontana,
it includes Gateway-to-Gateway and Client-to-Gateway.
(Total at MONITOR > VPN Monitor > IPSec )
Sorry for late response.So.If I have 350 Site-to-site active tunnels, i cannot have more than 150 IPSEC and L2TP client-to-Zyxel connections?0
Hi @mMontana,
Yes, maximum connections is total quantity.0
- 588 USG FLEX H Series
- 477 News and Release
