NWA220AX-6E vs WAX620D-6E difference ?
tremor
tremor Posts: 2 image  Freshman Member
edited May 2024 in Wireless
what is the difference between these two 6GHz access points?
i don´t see any difference in the tec specs.
  • tremor
    Thanks for the quick reply.
    That explains that various online shops listed both APs with the same tec specs. The different antenna configuration is a bit of specific.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,391 image  Zyxel Employee
    The difference between NWA220AX-6E vs WAX620D-6E is antenna type.
    NWA220AX-6E with 4x4 + 2x2 MIMO embedded antenna. Ceiling-mount patterns for NWA220AX-6E.
    WAX620D-6E with 4x4 + 2x2 dual-optimized antenna. Ceiling-mount and Wall-mount patterns for WAX620D-6E.
                               Ceiling-mount                                                             Wall-mount
    In case using WAX620D-6E, you can choose Antenna setting as Ceiling or Wall.
    On Nebula, go to Access point > Configure >Radio setting > Click AP
    On Standalone, go to Maintenance > Antenna > Antenna Switch
    Zyxel_Judy
  • tremor
  • Zyxel_Judy
    edited January 2023
    Hi @tremor,
    In addition, there are differences between Operating mode and Conducted typical transmit output power.
    1. Operating mode:
    NWA220AX-6E: Nebula Cloud managed/ standalone
    WAX620D-6E: Nebula Cloud managed/controller-managed/standalone
    2. At 5GHz, the output power of WAX620D-6E is bigger than NWA220AX-6E 3dBm.
    To get the full spec, please refer to these datasheets:
    NWA220AX-6E datasheet
    WAX620D-6E datasheet
    Zyxel_Judy
  • mw_dw
    mw_dw Posts: 10 image  Freshman Member
    I was just looking for this same info to this question. Glad to see it already posted. thanks.
  • JoeCraw
    JoeCraw Posts: 15 image  Freshman Member
  • Zyxel_Judy
    Hi @JoeCraw ,
    Thank you for your feedback.
    Related to NWA220AX-6E's antenna type, please refer to the datasheet. We will correct the information in the Specification file.
    Zyxel_Judy
