BWM for traffic from VPN to WAN
Christian78
Christian78 Posts: 8 image  Freshman Member
Hi!
Besides a few BWM rules that I already have in place in our ATP500 and VPN310, I would like to add a rule for all users connecting via VPN. I would like to restrict their bandwidth FROM the entire VPN zone TO the WAN interface. Therefore I've set up this rule:
Unfortunately, it doesn't work. The users who connect to the network via VPN have the full WAN bandwidth available, regardless which Priority I choose in the section "Bandwidth Shaping". I somehow have the feeling that I messed it up the Incoming Interface and the Outgoing Interface, but I can't figure out what I've done wrong.
What I need is a simple rule to limit the bandwidth from any VPN user to any outgoing WAN connection.
What did I do wrong? Any help is appreciated!
Chris
  • Zyxel_James
    Zyxel_James Posts: 809 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    Changing priority won't affect the bandwidth. The device gives bandwidth to higher-priority traffic first, until it reaches its configured bandwidth rate, so if there is no other traffic with higher priority, the lower-priority traffic can get the full bandwidth.
    I suggest changing the outgoing/incoming interface and Source/Destination settings.
    Outgoing: any
    Incoming: any
    Source: RemoteAccess_L2TP_Wiz_CLIENT 192.168.50.1/24  (L2TP client subnet)
    Destination: any
    Guaranteed Bandwidth: Inbound/Outbound: 500 kbps
    so that the L2TP client will match the Criteria while accessing the internet, then the traffic will be limited.
    James
  • Christian78
    Hello @Zyxel_James
    Thank you very much! I will try this. But isn't it the case that with the config you suggested, the traffic to the local networks is limited then, too?
    But I will play around a bit with it. Maybe the combination of defining the Source as L2TP subnet clients with a Destination will do the trick.
    Thanks once again for your help!
    Christian
  • Zyxel_James
    edited January 2023
    Yes, based on my suggestion, the traffic from RemoteAccess_L2TP_Wiz_CLIENT to Any will be limited, which includes to local network, you may adjust the Destination according to your needs.
  • Christian78
    Hi James,
    unfortunately, your first suggestion did not work as well. There is no change in the behavior at all.
    Christian
  • Zyxel_James
    edited January 2023
    Hi Christian78
    May I know how you test it? and please provide the topology of your network.
    You may also contact me via private message for further investigation, thanks.
