The new Update with Public IP for DDNS
I little hard to tell if it works due to the way it works.
So the way it works is on boot up it updates the IP DDNS then after that checks if that IP has changed after every 5 mins. Which is fine but if you update your DDNS by website the Zywall does not know this.
The idea I had in mind was to update the DDNS every 5mins EVEN if you IP has not changed.
I worked how to trick it into updating the IP to DDNS was simple really setup a HTTP server with a HTML file with text “192.168.100.1” setup checking Public IP URL to like http://192.168.44.4/ip.html this then makes the DDNS think the IP has change then does a IP check to your DDNS for the right IP.
Nope seems like the IP checker is independent from the DDNS IP checker
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 455 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 436 News and Release
- 91 Security Highlight
