Wirless lan
From your description, we assume that you had some configuration on standalone mode. After that, you registered the AP to the Nebula and found that the configuration was changed.
The reason is that when AP goes to the Nebula, AP will use the configuration from Nebula. It is that normal behavior of AP.
In case, there is different problem for your case, please share us more detail information.
Zyxel_Judy
I want to use this stand Alon, But after configuration when i connect to internet its auto reset after some time,
please suggest, or share contact so we can discussd0 -
From the diagnostic file that you provided via private message, we found that your AP is in cloud mode - The AP register at Nebula https://nebula.zyxel.com/
In case you’d like to use the Standalone mode, please go to Nebula > Organization-wide > Configure > License & Inventory > Choose your NWA1123AC-V2.
Click Actions > Remove from organization
And then reset your NWA1123AC-V2, your AP will rollback to standalone mode.
Zyxel_Judy
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 495 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 48 Wireless Ideas
- 286 Service & License
- 456 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
