Wirless lan
san_mce
san_mce Posts: 2
edited May 2024 in Wireless
AP auto reset after connect internet
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Guru Member
    From your description, we assume that you had some configuration on standalone mode. After that, you registered the AP to the Nebula and found that the configuration was changed.
    The reason is that when AP goes to the Nebula, AP will use the configuration from Nebula. It is that normal behavior of AP.
    In case, there is different problem for your case, please share us more detail information.
    Zyxel_Judy
    Untitled Image
  • I want to use this stand Alon, But after configuration when i connect to internet its auto reset after some time,
    please suggest, or share contact so we can discussd
  • Zyxel_Judy
    From the diagnostic file that you provided via private message, we found that your AP is in cloud mode - The AP register at Nebula https://nebula.zyxel.com/
    In case you’d like to use the Standalone mode, please go to Nebula > Organization-wide > Configure > License & Inventory > Choose your NWA1123AC-V2.
    Click Actions > Remove from organization
    And then reset your NWA1123AC-V2, your AP will rollback to standalone mode.
    Zyxel_Judy
    Untitled Image
