Vlan between a windows pc and raspbian
Hi Nami,
maybe we could have some hint now: I first applied only untagged VLAN10 on port 3 and nothing changed, when I applied also PVID 10 on port 3 the communication with RPi (on VLAN 1 subnet also) stopped working.
That could be because there is something wrong on the RPi side...
- this is the output of lsmod | grep 8021q8021q 32768 0garp 16384 1 8021q
- this is the output of modinfo 8021qfilename: /lib/modules/5.15.84-v7+/kernel/net/8021q/8021q.ko.xzversion: 1.8license: GPLalias: rtnl-link-vlansrcversion: 2027994B2785298484F5DDFdepends: garpintree: Yname: 8021qvermagic: 5.15.84-v7+ SMP mod_unload modversions ARMv7 p2v8
- this is the content of /etc/network/interfaces# interfaces(5) file used by ifup(8) and ifdown(8)# Include files from /etc/network/interfaces.d:source /etc/network/interfaces.d/*
- this is the content of /etc/network/interfaces.d/vlansauto eth0 eth0.10iface eth0 inet manualup ifup eth0.10iface eth0.10 inet manual# vlan-raw-device eth0
- this is the content of /etc/dhcpcd.confinterface eth0noipv6noipv6rsstatic ip_address=192.168.1.212/24static routers=192.168.1.1static domain_name_servers=1.1.1.1#interfaccia eth0.10 VLAN10interface eth0.10noipv6noipv6rsstatic ip_address=192.168.10.10/24static routers=192.168.10.1
I add also something else, if I do a ping from RPi and use tcpdump to analyze packets exiting from (in my mind) eth0.10 I see nothing at all otherwise using the flag -i eth0 instead of -i eth0.10 I can see from tcpdump (on eth0) the vlan packets.
now I'm getting a bit confused...tcpdump -e vlan -i eth0 -nntcpdump: verbose output suppressed, use -v[v]... for full protocol decodelistening on eth0, link-type EN10MB (Ethernet), snapshot length 262144 bytes12:33:16.708766 xx:xx:xx:xx:xx > ff:ff:ff:ff:ff:ff, ethertype 802.1Q (0x8100), length 46: vlan 10, p 0, ethertype ARP (0x0806), Request who-has 192.168.10.100 tell 192.168.10.10, length 2812:33:17.715786 xx:xx:xx:xx:xx > ff:ff:ff:ff:ff:ff, ethertype 802.1Q (0x8100), length 46: vlan 10, p 0, ethertype ARP (0x0806), Request who-has 192.168.10.100 tell 192.168.10.10, length 2812:33:18.755784 xx:xx:xx:xx:xx > ff:ff:ff:ff:ff:ff, ethertype 802.1Q (0x8100), length 46: vlan 10, p 0, ethertype ARP (0x0806), Request who-has 192.168.10.100 tell 192.168.10.10, length 2812:33:19.796516 xx:xx:xx:xx:xx > ff:ff:ff:ff:ff:ff, ethertype 802.1Q (0x8100), length 46: vlan 10, p 0, ethertype ARP (0x0806), Request who-has 192.168.10.100 tell 192.168.10.10, length 28obviously nothing changes about the ping test.
let me know if you need other infos.
Regards0 -
grip said:
The above looks correct
Realtek utility doing VLANs should work but not that great MTU reduced.
Better way is to enable Hyper-V services
Then use Windows PowerShell
New-VMSwitch -Name "External_network" -NetAdapterName "Ethernet"
Add-VMNetworkAdapter -ManagementOS -Name VLAN10 -SwitchName External_network
Set-VMNetworkAdapterVlan -ManagementOS -VMNetworkAdapterName VLAN10 -Access -VlanID 10
Not possible as the VLAN tags is removed before & after Wireshark can see itZyxel_Nami said:we advise that you may check the packet frame by Wireshark on both hosts to see if the packets sending from these two hosts are really added VLAN 10 tags or not.0 -
Hi @grip
PVID configuration is for incoming untagged packets to every port that if NIC doesn’t support VLAN tagging then the switch will add specified PVID on the packets.
For Tag Egress/Untag Egress Member configuration, Switch decides whether outgoing frame should carry VLAN tags or not.
Regarding to our recent advice of changing into PVID 10 on port 3, the communication with RPi stopped working on VLAN 1 subnet because eth0 (192.168.1.212) on RPi was untagged, then when the packet came to port 3, it was assigned PVID 10 and it couldn’t ping 192.168.1.156 since they were not in same VLAN anymore.
Also, when you changed into PVID 10 and untagged VLAN 10 on port 7 while port 3 remained tagged VLAN 10 and PVID 1, the outgoing frame from port 3 to host 192.168.10.10 (eth0.10) should be successful.
Therefore, we would like to ask if you can test VLAN 1/ VLAN 10 communication on only physical interface as below illustration:
VLAN 1
VLAN 10
If VLAN 1/VLAN 10 hosts can communicate with each other on the physical interface, then we would like to advise you to check on your settings of virtual interface.
Hi @PeterUK
If NIC supports VLAN tagging, you can see it on 802.1Q tab in Wireshark. This tab can be added on Wireshark setting.
Best Regards
Nami
Nami
Hi Peter,
I did what you suggested (I have to better understand the issue with the MTU): deleted any new interface created by the Realtek utility and created the new one with Hyper-V toolsScheda Ethernet vEthernet (VLAN10):Suffisso DNS specifico per connessione:Descrizione . . . . . . . . . . . . . : Hyper-V Virtual Ethernet Adapter #3Indirizzo fisico. . . . . . . . . . . : xx-xx-xx-xx-xx-xxDHCP abilitato. . . . . . . . . . . . : NoConfigurazione automatica abilitata : SìIndirizzo IPv6 locale rispetto al collegamento . : fe80::5cb9:xxxx:xxxx:xxxx%60(Preferenziale)Indirizzo IPv4. . . . . . . . . . . . : 192.168.10.100(Preferenziale)Subnet mask . . . . . . . . . . . . . : 255.255.255.0Gateway predefinito . . . . . . . . . :IAID DHCPv6 . . . . . . . . . . . : 1006638429DUID Client DHCPv6. . . . . . . . : 00-01-00-01-27-AD-xx-xx-xx-xx-xx-xx-xx-xxServer DNS . . . . . . . . . . . . . : fec0:0:0:ffff::1%1fec0:0:0:ffff::2%1fec0:0:0:ffff::3%1NetBIOS su TCP/IP . . . . . . . . . . : Attivato
but nothing changed...
Regards
Hi @grip
We reproduced the environment using Realtek Diagnostic Utility and Raspberry Pi:
Switch GS1200-8HPv2: VLAN configuration as below image:
Windows PC: we added VLAN 10 by Realtek Diagnostic Utility
After adding VLAN 10 successfully by Realtek Diagnostic Utility, we assigned static IP 192.168.10.100 for Realtek Virtual Adapter at Network Connections > choose Realtek Virtual Adapter > Properties > Internet Protocol Version 4 (TCP/IPv4).
Then checking information of Realtek Virtual Adapter on the utility, IP 192.168.10.100 was assigned on this adapter as below image:
Also, we checked on CMD that showed successfully IP address 192.168.10.100 and the original one as 192.168.1.100.
And here is the result of ping from Windows side:
Raspberry Pi: please check the interface and ping result as following image:
eth0: 192.168.1.10
eth0.10: 192.168.10.10
Everything seems normal as shown. Therefore, in order to solve your issue, we would like to share our experiences when we did the test that may help you with finding the reason:
We encountered the failed settings on Realtek Diagnostic Utility at the first time that made the original one (192.168.1.100) disappeared. Then we uninstalled and installed it again, after that we assigned static IP 192.168.10.100 for Realtek Virtual Adapter as above instruction. Please double check your settings for VLAN 10 on Windows.
On your first message, there is ‘vlan protocol 802.1Q id 10’ on the interface eth0.10, meanwhile we don’t have this line on our eth0.10 interface. When setting VLAN on Raspberry, we followed the instruction of this blog, please check if it helps. https://engineerworkshop.com/blog/raspberry-pi-vlan-how-to-connect-your-rpi-to-multiple-networks/
Windows can ping Raspberry Pi, but the Raspberry Pi can’t ping Windows. It was because Firewall was enabled on Windows, please check this also. You may try to disable Firewall policy build-in on Windows temporary for test.
For identifying whose settings aren’t correct, please try ping test at the same time:
Windows pings Pi’s VLAN 1, VLAN 10
Pi pings Windows’s VLAN 1, VLAN 10
Hope these inputs help to fix your issue
NamiNami
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 482 News and Release
