Vlan between a windows pc and raspbian
2»
  • grip
    grip Posts: 10 image  Freshman Member
    edited January 2023
    Hi Nami,
    maybe we could have some hint now: I first applied only untagged VLAN10 on port 3 and nothing changed, when I applied also PVID 10 on port 3 the communication with RPi (on VLAN 1 subnet also) stopped working.
    That could be because there is something wrong on the RPi side...
    - this is the output of lsmod | grep 8021q
    8021q                  32768  0
    garp                   16384  1 8021q
    -  this is the output of modinfo 8021q
    filename:       /lib/modules/5.15.84-v7+/kernel/net/8021q/8021q.ko.xz
    version:        1.8
    license:        GPL
    alias:          rtnl-link-vlan
    srcversion:     2027994B2785298484F5DDF
    depends:        garp
    intree:         Y
    vermagic:       5.15.84-v7+ SMP mod_unload modversions ARMv7 p2v8
    - this is the content of /etc/network/interfaces
    # interfaces(5) file used by ifup(8) and ifdown(8)
    # Include files from /etc/network/interfaces.d:
    source /etc/network/interfaces.d/*
    - this is the content of /etc/network/interfaces.d/vlans
    auto eth0 eth0.10
    iface eth0 inet manual
            up ifup eth0.10
    iface eth0.10 inet manual
    #       vlan-raw-device eth0
    - this is the content of /etc/dhcpcd.conf
    interface eth0
    noipv6
    noipv6rs
    static ip_address=192.168.1.212/24
    static routers=192.168.1.1
    static domain_name_servers=1.1.1.1
    #interfaccia eth0.10 VLAN10
    interface eth0.10
    noipv6
    noipv6rs
    static ip_address=192.168.10.10/24
    static routers=192.168.10.1
    I add also something else, if I do a ping from RPi and use tcpdump to analyze packets exiting from (in my mind) eth0.10 I see nothing at all otherwise  using the flag -i eth0 instead of -i eth0.10 I can see from tcpdump (on eth0) the vlan packets.
    now I'm getting a bit confused...
    tcpdump -e vlan -i eth0 -nn
    tcpdump: verbose output suppressed, use -v[v]... for full protocol decode
    listening on eth0, link-type EN10MB (Ethernet), snapshot length 262144 bytes
    12:33:16.708766 xx:xx:xx:xx:xx > ff:ff:ff:ff:ff:ff, ethertype 802.1Q (0x8100), length 46: vlan 10, p 0, ethertype ARP (0x0806), Request who-has 192.168.10.100 tell 192.168.10.10, length 28
    12:33:17.715786 xx:xx:xx:xx:xx > ff:ff:ff:ff:ff:ff, ethertype 802.1Q (0x8100), length 46: vlan 10, p 0, ethertype ARP (0x0806), Request who-has 192.168.10.100 tell 192.168.10.10, length 28
    12:33:18.755784 xx:xx:xx:xx:xx > ff:ff:ff:ff:ff:ff, ethertype 802.1Q (0x8100), length 46: vlan 10, p 0, ethertype ARP (0x0806), Request who-has 192.168.10.100 tell 192.168.10.10, length 28
    12:33:19.796516 xx:xx:xx:xx:xx > ff:ff:ff:ff:ff:ff, ethertype 802.1Q (0x8100), length 46: vlan 10, p 0, ethertype ARP (0x0806), Request who-has 192.168.10.100 tell 192.168.10.10, length 28
    obviously nothing changes about the ping test.
    let me know if you need other infos.
    Regards
    PeterUK Posts: 4,212 image  Guru Member
    grip said:
    The above looks correct
    Realtek utility doing VLANs should work but not that great MTU reduced.
    Better way is to enable Hyper-V services
    Then use Windows PowerShell
    New-VMSwitch -Name "External_network" -NetAdapterName "Ethernet"
    Add-VMNetworkAdapter -ManagementOS -Name VLAN10 -SwitchName External_network
    Set-VMNetworkAdapterVlan -ManagementOS -VMNetworkAdapterName VLAN10 -Access -VlanID 10
    edited January 2023
    we advise that you may check the packet frame by Wireshark on both hosts to see if the packets sending from these two hosts are really added VLAN 10 tags or not.
    Not possible as the VLAN tags is removed before & after Wireshark can see it
  • Zyxel_Nami
    Zyxel_Nami Posts: 659 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate
    Hi @grip
    PVID configuration is for incoming untagged packets to every port that if NIC doesn’t support VLAN tagging then the switch will add specified PVID on the packets.
    For Tag Egress/Untag Egress Member configuration, Switch decides whether outgoing frame should carry VLAN tags or not.
    Regarding to our recent advice of changing into PVID 10 on port 3, the communication with RPi stopped working on VLAN 1 subnet because eth0 (192.168.1.212) on RPi was untagged, then when the packet came to port 3, it was assigned PVID 10 and it couldn’t ping 192.168.1.156 since they were not in same VLAN anymore.
    Also, when you changed into PVID 10 and untagged VLAN 10 on port 7 while port 3 remained tagged VLAN 10 and PVID 1, the outgoing frame from port 3 to host 192.168.10.10 (eth0.10) should be successful.
    Therefore, we would like to ask if you can test VLAN 1/ VLAN 10 communication on only physical interface as below illustration:
    VLAN 1
    VLAN 10
    If VLAN 1/VLAN 10 hosts can communicate with each other on the physical interface, then we would like to advise you to check on your settings of virtual interface.
    Hi @PeterUK
    If NIC supports VLAN tagging, you can see it on 802.1Q tab in Wireshark. This tab can be added on Wireshark setting.
    Best Regards
    Nami
    Nami
  • grip
    Hi Peter,
    I did what you suggested (I have to better understand the issue with the MTU): deleted any new interface created by the Realtek utility and created the new one with Hyper-V tools
    Scheda Ethernet vEthernet (VLAN10):
       Suffisso DNS specifico per connessione:
       Descrizione . . . . . . . . . . . . . : Hyper-V Virtual Ethernet Adapter #3
       Indirizzo fisico. . . . . . . . . . . : xx-xx-xx-xx-xx-xx
       DHCP abilitato. . . . . . . . . . . . : No
       Configurazione automatica abilitata   : Sì
       Indirizzo IPv6 locale rispetto al collegamento . : fe80::5cb9:xxxx:xxxx:xxxx%60(Preferenziale)
       Indirizzo IPv4. . . . . . . . . . . . : 192.168.10.100(Preferenziale)
       Subnet mask . . . . . . . . . . . . . : 255.255.255.0
       Gateway predefinito . . . . . . . . . :
       IAID DHCPv6 . . . . . . . . . . . : 1006638429
       DUID Client DHCPv6. . . . . . . . : 00-01-00-01-27-AD-xx-xx-xx-xx-xx-xx-xx-xx
       Server DNS . . . . . . . . . . . . .  : fec0:0:0:ffff::1%1
                                               fec0:0:0:ffff::2%1
                                               fec0:0:0:ffff::3%1
       NetBIOS su TCP/IP . . . . . . . . . . : Attivato
    but nothing changed...
    Regards
  • Zyxel_Nami
    Hi @grip
    We reproduced the environment using Realtek Diagnostic Utility and Raspberry Pi:
    • Switch GS1200-8HPv2: VLAN configuration as below image:
    • Windows PC: we added VLAN 10 by Realtek Diagnostic Utility
    After adding VLAN 10 successfully by Realtek Diagnostic Utility, we assigned static IP 192.168.10.100 for Realtek Virtual Adapter at Network Connections > choose Realtek Virtual Adapter > Properties > Internet Protocol Version 4 (TCP/IPv4).
    Then checking information of Realtek Virtual Adapter on the utility, IP 192.168.10.100 was assigned on this adapter as below image:
    Also, we checked on CMD that showed successfully IP address 192.168.10.100 and the original one as 192.168.1.100.
    And here is the result of ping from Windows side:
    • Raspberry Pi: please check the interface and ping result as following image:
    • eth0: 192.168.1.10
    eth0.10: 192.168.10.10
    Everything seems normal as shown. Therefore, in order to solve your issue, we would like to share our experiences when we did the test that may help you with finding the reason:
    • We encountered the failed settings on Realtek Diagnostic Utility at the first time that made the original one (192.168.1.100) disappeared. Then we uninstalled and installed it again, after that we assigned static IP 192.168.10.100 for Realtek Virtual Adapter as above instruction. Please double check your settings for VLAN 10 on Windows.
    • On your first message, there is ‘vlan protocol 802.1Q id 10’ on the interface eth0.10, meanwhile we don’t have this line on our eth0.10 interface. When setting VLAN on Raspberry, we followed the instruction of this blog, please check if it helps. https://engineerworkshop.com/blog/raspberry-pi-vlan-how-to-connect-your-rpi-to-multiple-networks/
    • Windows can ping Raspberry Pi, but the Raspberry Pi can’t ping Windows. It was because Firewall was enabled on Windows, please check this also. You may try to disable Firewall policy build-in on Windows temporary for test.
    For identifying whose settings aren’t correct, please try ping test at the same time:
    • Windows pings Pi’s VLAN 1, VLAN 10
    • Pi pings Windows’s VLAN 1, VLAN 10
    Hope these inputs help to fix your issue
    Nami
    Nami
