connect Qnap storage to Zyxel XS1930-12HP 10Gbit port
StephenZweig
in Switch
Hi!
Is ti possible to connect my Qnap storage with SFP+ port to Zyxel XS1930-12HP 10Gbit SFP+ port?
Can I use Zyxel DAC10G-3M-ZZ0103F for this purpose?
Some people report that it's for stacking only
Best regards, Stephen
Hi! Finally bought and tested the cable. It doesn't work.
No link. Status is disconnected.
Looks like the problem is on QNAP side.0
Hi @StephenZweig
Welcome to the Zyxel community!
The DAC cable is not for stacking only.
And I'm not sure if anyone has used Zyxel DAC10G-3M-ZZ0103F on Qnap storage, maybe you can wait for other users to share their experiences here.Zyxel Melen0 -
Hi StephenI used to connect with a dac cable in one of my clients, it works fine.1
- 588 USG FLEX H Series
- 476 News and Release
