Current firmware for GS1500-24 switch?
jima
jima Posts: 2
Yes, I know it is end of life but it still works if you use an old browser.
My switch has firmware: V1.00(BVN.2)b18.
Is there newer firmware and where can I download it
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,707  Zyxel Employee
    Hi @jima,
    The firmware you are using is the latest (date code) firmware.
    Zyxel Melen
  • Zyxel_Melen
    Hi @jima,
    Zyxel Melen
  • Hun
    Hun Posts: 18  Freshman Member
    Hello, can you please where can I get this firmware?
    I have GS1500-24PV1.00(BPW.2), is this the same, could I use the one you're usinG
    Thanks for your time.
  • jima
    jima Posts: 2
    I bought the switch several years ago used with this firmware and don't have any firmware files.
  • Zyxel_Melen
    Hi @Hun,
    The V1.00(BPW.2) is the last firmware of GS1500-24P.
    Zyxel Melen
