Stock issue with some Zyxel products
Hi @PeterUK,
Currently, vpn series in constraint so there is no ETA.
I would recommend to buy the ATP/FLEX series.
Thank you
Kevin0 -
Yes I could do that but even some of the other model have stock issue.
Really like the VPN series as I don't need the extra stuff the ATP/FLEX series have plus better price to performance.
Do you know if there are any new models coming out?
Hi @PeterUK,If you need VPN features only, we suggest you choose USG FLEX non-bundle models. Besides, the 3rd generation USG FLEX H series will be launched in Q2 this year.0
Hi @jonatan,The new models will be announced around Jun. 2023.0
Your EOL the VPN series line up on 2023-09-30 ? bit soon given the slower USG20W-VPN are not EOL?
But on a plus note many thanks for updateing the older USG to patch Vulnerabilities
- 588 USG FLEX H Series
- 476 News and Release
