Connection Site to site Ipsec VPN
Hello @Thierry2Zyxel does not block ICMP through the VPN tunnel by default, it could be blocked due to your routing policy or security policy, please check if there is any log about it.Moreover, you may refer to this articleJames0
HelloThanks for your answerNo i have no special Policy rule that can block ICMP0
Hello @Thierry2Is it only ICMP traffic that does not respond?Very common is that the destination does not respond to ping. Often Windows servers do filter the ping. Or the local routing table of the ping destination might have conflicting routing rules.Please observe Monitor -> VPN Monitor -> IPsec when pinging and see if the packet is entering the tunnel ("Inbound bytes" should be counting up). If the packet enters the tunnel, check if it leaves the tunnel on the other site ("Outbound bytes" should be counting up) and if the ping reply is hitting the LAN interface again. You can use packet captures to verify that.James0
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 516 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 289 Service & License
- 461 News and Release
- 4.3K FAQ
- 97 Security Highlight
