NWA210AX: possible to select WPA3 security only?
I find that my NWA210AX allows WPA2 clients to connect, even though I have Security Mode set to "wpa3" in the active security profile. I gather this is because of the Transition Mode checkbox, which is enabled and grayed out so that I can't change it. How can I configure it to allow WPA3 only?
Hi @tgl,
You’re right. WPA3 with a “Transition mode” is provided to let non-support devices connect to SSID in WPA2-Personal. The “Transition mode” is enabled and grayed out as default.
In case you just want to the WPA3-supported clients connect to the SSID, you can use the CLI as below, SSID with SECURITY4 as example.
Router> enable
Router# configure terminal
Router(config)# wlan-security-profile SECURITY4
Router(config-wlan-security SECURITY4)# no transition-mode
Router(config-wlan-security SECURITY4)# exit
Verification: A WPA3 non-supported laptop can’t connect to the SSID with security as WPA3 and no transition mode.
Zyxel_Judy
Hi @tgl,
Router> enable
Zyxel_Judy
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 288 Service & License
- 458 News and Release
- 4.3K FAQ
- 97 Security Highlight
