Rules for drop dns bypass, vpn, TeamViewer
Maybe look at it the other way if you can inserted of block only allow given access to URL and ports and block everything else?
VPN can be hard to block when using port 443.
You can use APP patrol to select tunnelling & Thin Client and drop all.
Hi @jyjoe,You can use DNS Content Filter to block Teamviewer. Go to Security Service > Content Filter > DNS Content Filter > General and click "Add" to create a new profile. In the profile, select "Remote Access" and click "OK".
You can also add your own block list. Then apply the profile to security policy rule from LAN1/LAN2 to Any and from LAN1/LAN2 to ZyWALL.
Hi @jyjoe,To block OpenVPN and Wireguard, we suggest you use App Patrol to block VPN. In App Patrol, create a new profile and select "OpenVPN" and "Wireguard". Then apply the profile to security policy rule (outgoing rule). You can consider USG FLEX 100 or ATP100. Both models support App Patrol.
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 516 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 289 Service & License
- 461 News and Release
- 4.3K FAQ
- 97 Security Highlight
