Suggestions for device web interfaces
System
Admin
Admin
This discussion was created from comments split from: Seriously, your ideas could be new feature for Zyxel products!.
Suggestions for device web interfaces:1. Let an english literate go through text in the interface. There are consistent errors in endings. In particular d's and s's are missing. E.G. in settings dialogues: Incorrect current spelling "Advance". Correct and meaningful: "Advanced".2. Allow spaces in all user input, as long as it is not in conflict with relevant RFC's.3. Almost all input fields should be made longer. In particular droplists that hold object names, are annoyingly short.3. Any configuration object should be clonable. There is no reason not to implement a cloning feature like the one in "Security Policy/Policy Control"0
Most important, field size is in fact ridicules. In fact, there should actually be a split screen/table, so you can scroll through the objects on the right.
life would be so easy.
E.G.: Image from Cisco ASA ASDM
And hitcounts on ACL0
- 441 Beta Program
- 293 Service & License
