"UAG50" SSL by default expired, how upgrade it ?
Hello Guys,
The SSL certificate on UAG50 is expired in 2019. how to upgrade it ?
I generate one certificate here : https://en.rakko.tools/tools/46/ but i have an error at login page, when i activate login ssl page.
Thank you.
UAG50
The UAG50 is EOL. If you cannot enter the device Web-GUI due to the trusted certificate. You could use the CLI to disable this feature.but i have an error at login page, when i activate login ssl page.Router> configure terminalRouter(config)# no ip http secure-server auth-client
And then you could enter the device Web-GUI successfully.0 -
Thank You for your response.The UAG50 dont have an administrative Port. There is 1 WAN Port and Mini-USB Port for LAN.Could i use the WAN Port ?Reagrds0
Hi @UAG50
May I know did you ever tried to reset the UAG50 and enter the device Web-GUI? Is it OK for you?0 -
Hi @UAG50
Besides, not sure if you encounter the TLS handshake issue for the EOL legacy model, you could refer to the FAQ(How to enter the login page of the legacy device?) to see how to enter the legacy model . You could enter the device login page via the Edge browser and click “Reload tab in Internet Explorer mode” on the upper right corner
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
