"UAG50" SSL by default expired, how upgrade it ?
UAG50
UAG50 Posts: 4
edited February 2023 in Security
Hello Guys,
The SSL certificate on UAG50 is expired in 2019. how to upgrade it ?
I generate one certificate here : https://en.rakko.tools/tools/46/ but i have an error at login page, when i activate login ssl page.
Thank you.
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,333  Zyxel Employee
    UAG50
    The UAG50 is EOL. If you cannot enter the device Web-GUI due to the trusted certificate. You could use the CLI to disable this feature.
    Router> configure terminal
    Router(config)# no ip http secure-server auth-client
    And then you could enter the device Web-GUI successfully.
  • UAG50
    UAG50 Posts: 4
    Thank You for your response.
    The UAG50 dont have an administrative Port. There is 1 WAN Port and Mini-USB Port for LAN.
    Could i use the WAN Port ?
    Reagrds
  • Zyxel_Jeff
    Hi @UAG50
    May I know did you ever tried to reset the UAG50 and enter the device Web-GUI? Is it OK for you?
  • Zyxel_Jeff
    Hi @UAG50
    Besides, not sure if you encounter the TLS handshake issue for the EOL legacy model, you could refer to the FAQ(How to enter the login page of the legacy device?)  to see how to enter the legacy model  . You could enter the device login page via the Edge browser and click “Reload tab in Internet Explorer mode” on the upper right corner :) .
