<SOLVED> VLAN: broadcast and multicast packet handling on the XGS1210-12
Best Answers
Hi @eolo
Basing on your provided firmware version and VLAN configuration screenshots, we did a test on our XGS1210-12 between port 5 (VLAN 17) and port 10 (VLAN 1, 835) by sending broadcast packets between PC A and PC B. As we observed packet by Wireshark, there are not any packets forwarding from these two stations.
In order to investigate and solve your problems, we would like to send you a private message to ask about your topology, running-config and Wireshark screenshots or packet file directly.
Best Regards,
Nami
Nami
Sorry, it was my mistake, to capture the traffic I used port mirroring without removing the monitor port from the vlan. I removed the monitor port from the vlan and now it works as expected. Thanks for the quick support.
Hi @eolo
Best Regards,
Nami
Nami
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
