Cannot add more than 200 IPs, solution?
ifly
ifly Posts: 2 image  Freshman Member
In the ZyWALL USG 100 in the Object > Address section I cannot add more than 200 IPs. how do i block spam ip?
    Every USG has its limits you may look at getting a more powerful model and run them in series.
  • ifly
    there is no automatism on this model to block ddos ​​or multiple accesses from the same ip?
  • Zyxel_Emily
    Hi @ifly,
    ZyWALL USG 100 supports up to 200 address objects. You can try to enable ADP and modify the threshold of UDP Flood in Traffic Anomaly.
    Since ZyWALL USG 100 is EOL and IDP license for this model is unavailable, we recommend you ATP200 or USG FLEX 200. You can use IPS to block DDoS attack or Geo IP to block suspect access from a certain country/region.
