Cannot add more than 200 IPs, solution?
Every USG has its limits you may look at getting a more powerful model and run them in series.
there is no automatism on this model to block ddos or multiple accesses from the same ip?
Hi @ifly,ZyWALL USG 100 supports up to 200 address objects. You can try to enable ADP and modify the threshold of UDP Flood in Traffic Anomaly.
Since ZyWALL USG 100 is EOL and IDP license for this model is unavailable, we recommend you ATP200 or USG FLEX 200. You can use IPS to block DDoS attack or Geo IP to block suspect access from a certain country/region.0
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
