confused with zywall models usg60 / usg100 / usg20
asiawatcher
Hi there guys, which model is newer usg60 or usg100 ?
usg60 GUI and speed looks much better and faster than usg100 even after firmware upgrade
how about USG20 ?? newer or older than the usg100 and usg60 ??
thanks
thanks
Best Answers
The USG60 is the newest but is EOL as is USG100 and USG20 unless its the USG20-VPN which is slower then the USG60.
Best to go by the SPI and what listed by the site to not get a old model
not sure which is oldest but the USG20 is slowerasiawatcher said:how about usg100 and usg20 which is the slowest and oldest0 -
If USG20 is this device.asiawatcher said:hi thanks for your reply how about usg100 and usg20 which is the slowest and oldest of the 2 ?
is not older but is slower than USG100.
Instead, if USG20 actually is this device
actually is USG20-VPN, which is newer and probably faster than USG100 but have less features and is still supported by Zyxel with newer firmwares (as USG Flex 50)
AFAIK no. However USG20-VPN is still supported, USG60 no.
For comparison, you can look up for specs table about the features of all the models..
USG100 is certainly slower than USG60 (which mostly replaced it)1 -
USG20-vpn also known as FLEX50 is next-gen product. It is newer than usg60.
But USG60 is faster than USG20-vpn
However, the most important is that USG20-VPN still supported by Zyxel and USG60 had been End of support.
hi thanks for your reply how about usg100 and usg20 which is the slowest and oldest of the x2 ? I'm very confused with the model numbers.
cheers0 -
actually is USG20-VPN, which is newer and probably faster than USG100 but have less features and is still supported by Zyxel with newer firmwares (as USG Flex 50)0 -
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
