NWA50AX - Extend existing Wifi (SSID) without creating new SSID
Hi There
I've bought the AP NWA50AX to extend the wifi range without without sacrificing bandwidth as with a classic repeater.
So I've two WLAN-SSID (Home/Guest) configured on my internet-router. With which option within AP management --> MBSSID Settings is it possible two simply extend the existing wifi singal with the same SSID as they exist already from my internet router. My current setting in MBSSID Settings as a repeater doesn't work out, I see a total of four SSID from my network (2x internet-router SSID, 2x AP NWA50AX SSID).
Best regards
Mike
Best regards
Mike
Hi @WeeLannIn the repeater mode of Zyxel AP, it could only have a wireless connection with another Zyxel AP.However, you could make your internet-router has a same SSID and Security Settings with Zyxel APs to achieve the “roaming” function.Kay
Kay
Kay
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 288 Service & License
- 458 News and Release
- 4.3K FAQ
- 97 Security Highlight
